Adding to a Collector's Queue Without Using Worklists
This section discusses:
Pages Used to Add to a Collector's Queue Without Using Worklists
| Page Name | Definition Name | Navigation | Usage |
Collection Placement |
SSF_ASGN_COLLECTN |
Manually add students to collections without using the workflow process. |
SSF_ASGN_COLL_ORG |
Manually add corporations to collections without using the workflow process. |
Manually Adding Students To Collections Without Using The Workflow Process
Access the Collection Placement page ().
The Collection Placement page enables you to assign collectors to students or corporations. However, you must run the Credit History process first, which uses aging categories against students or corporations to determine who should be placed in collection
| Field or Control | Description |
ID |
Enter the student whom you want to add to collections. |
Reason In |
Enter the reason that the student is in collection. |
Collector Assigned |
Enter the collector. |
