Approval Framework Process Flow in Asset Management
This diagram outlines the steps in the inspection and assessment of the delivered setup and the required considerations to set up and implement workflow using the Approval Framework in your environment.
High Level Approval Framework Process Flow for Asset Management
High Level Asset Management Approval Framework Setup
Use of the Approval Framework requires the inspection of the delivered registration definitions, the approval configuration definitions, and the approval templates for changes that are necessary for your particular installation. Although sample business processes, activities, and business events are delivered with the product, you may need to modify and tailor them to your specific implementation requirements.
In addition to enabling the Approval Framework, you define the Asset Management approval user lists and Asset Management approval process rules.
