Setting Up Retirement Basis Reduction Codes
To set up retirement basis codes, use the Retirement Basis Reduction (TRAN_EXCLUDE_TBL) component.
This topic discusses how to define retirement basis codes.
Page Used to Set Up Retirement Basis Codes
Retirement Basis Reduction Page
TRAN_EXCLUDE_TBL
Set up retirement basis reduction codes.
Use the Retirement Basis Reduction page (TRAN_EXCLUDE_TBL) to set up retirement basis reduction codes.
Navigation:
Set Up Financials/Supply Chain, and then Product Related, and then Asset Management, and then Financials, and then AM Retirement Basis Reduction
These codes are used when you opt to retire an asset by using its original cost basis adjusted by all non-excluded transactions. In this way, for example, you could exclude any indexed revaluation adjustments.
For this option to work correctly, any transaction type or types that you want to exclude must have unique transaction codes.
