Tracking Asset Maintenance Contracts
This topic discusses how to track Asset Maintenance Contracts.
Pages Used to Track Asset Maintenance Contracts
| Page Name | Definition Name | Usage |
MAINT_CONTRACT_01 |
Add or modify maintenance contracts. |
MAINT_CONTRACT_02 |
Enter the terms of each maintenance contract and the coverage that it provides. |
Understanding Asset Maintenance Contracts
Use the Maintenance Contract Terms (MAINT_CONTRACT_01) component to track such contracts and to determine repair and servicing costs, the time period covered in the contract, and the exact coverage specified by the contract.
To track maintenance contracts:
Add or modify maintenance contracts on the Maintenance Contracts - Detail page.
You cannot set up maintenance contracts without first setting up a Vendor table. You need not set up all vendor tables, but you must at least set up a list of vendors.
Maintenance Contracts - Detail Page
Use the Maintenance Contracts - Detail page (MAINT_CONTRACT_01) to add or modify maintenance contracts.
Navigation:
You can add multiple records for any contract. By creating separate records with different dates in the Effective Date field, you can maintain a history of when the contract was first issued and any subsequent renewals. To identify the contract currently in use, make its Status Active.
The information in this page helps you to track maintenance contracts. You can enter when the contract was issued, when it expires, what you had to pay for it, and the vendor honoring the contract. You can also identify the person who is responsible for ensuring that the assets covered by this contract are maintained and repaired as required.
Maintenance Contracts - Coverage Page
Use the Maintenance Contracts - Coverage page (MAINT_CONTRACT_02) to enter the terms of each maintenance contract and the coverage that it provides.
Navigation:
In the Coverage field, enter any information about the coverage provided under each maintenance contract, the cost of such coverage, or any other contract-related information.
