Prerequisites for Defining Facilities
Before defining facilities you must define:
  • Counterparties
  • Settlement instructions
  • Method of facility review notification
To implement the Facility Review Workflow virtual approval methodology, use PeopleSoft Application Designer to define business processes, activities, business events, worklists, routings, and approval rule sets.
The integration between Treasury and Notification Framework will be delivered as system data to support email and worklist notifications, as shown in this table:
Description Process Name Process Category Navigation
Notify Facilities
TR_NOTIFICATIONS
FACILITIES
Enterprise Components, and then Events & Notifications, and then Notifications Framework, and then Notifications Registry
See the product documentation for PeopleTools: Application Designer Developer's Guide and PeopleSoft Events and Notifications Framework.
