Integrating Commitment Control with PeopleSoft Budgeting
You can export budget and ledger data from Commitment Control to Budgeting and load budgets from Budgeting to Commitment Control.
If Budgeting is installed, reference the appropriate documentation for detail instructions about creating budgets and sending them to Commitment Control.
Once the data is staged in the financial database, you can create an allocation set to extract the budget data and create budget journals for posting to Commitment Control ledgers.
