Setting Up Commitment Control Security Events
To set up commitment control security events, use the Events (KSEC_EVENT_ENTRY) component.
This section discusses how to activate security for specific Commitment Control functions, known as security events.
Page Used to Activate Security Events
Commitment Control Security Events Page
KSEC_EVENT_ENTRY
Activate and inactivate security for specific Commitment Control functions, or events.
Related Topics
Use the Commitment Control Security Events page (KSEC_EVENT_ENTRY) to activate and inactivate security for specific Commitment Control functions, or events.
Navigation:
Commitment Control, and then Define Budget Security, and then Activate KK Security Events
This example illustrates the fields and controls on the Commitment Control Security Events page.
Select the check box for any of the seven security events (Commitment Control functions) to which you want to restrict access or add constraints to the use of the events.
