Underlying Data Structure of PeopleSoft Commitment Control
Commitment Control uses the ledger and ledger group structure of General Ledger to store control budgets in the Commitment Control Ledger Data table (LEDGER_KK). Each control budget definition (or set of budgets sharing the same rules) is defined in the system as a Commitment Control ledger group consisting of Commitment Control ledgers, each of which stores a different amount type, such as pre-encumbrance, encumbrance, and expenditure.
A simple organization might have the following budget configuration:
  • An expenditure Commitment Control ledger group consisting of a budget ledger, pre-encumbrance ledger, encumbrance ledger, and expenditure ledger.
    That is to say, it consists of a ledger for control budget amounts and a ledger for each transaction amount type you process against your control budgets as shown in the following table:
    Ledger Group Budget Ledger Pre-encumbr Ledger Encumbr Ledger Expenditure Ledger
    ORG
    ORG_BUD
    ORG_PRE
    ORG_ENC
    ORG_EXP
    Some expenditure ledger groups may also include a planned ledger, which can be used for planned expenditures that have not yet solidified to the point of the need for the issuing of a requisition.
  • A revenue Commitment Control ledger group consisting of a revenue estimate budget ledger, a revenue recognized ledger, and a revenue collected ledger, as shown in the following table:
    Ledger Group Budget Ledger Recognized Ledger Collected Ledger
    REVEST
    REVEST_BUD
    REVEST_REC
    REVEST_COL
In other words, within a control budget definition, each amount type has its own bucket, and this structure is reflected in the ledger group and ledger structure.
The way control budget data is actually stored in the Commitment Control Ledger Data table is similar to this example:
Ledger Fiscal Year Acct Period Fund Account DeptID Budget Period Posted Total Amt
ORG_BUD
2009
1
100
50000
1000
2009
100000
ORG_PRE
2009
1
100
50000
1000
2009
30000
ORG_ENC
2009
3
100
50000
1000
2009
50000
ORG_EXP
2009
3
100
50000
1000
2009
25000
REVEST_BUD
2009
1
100
40000
1000
2009
125000
REVEST_REC
2009
1
100
40000
1000
2009
30000
REVEST_COL
2009
2
100
40000
1000
2009
50000
Each time a budget-checked transaction updates the Commitment Control Ledger Data table, it updates the posted total amount.
The remaining available budget balance is not a stored amount, but is calculated when you run budget checking.
Using the ledger table structure in General Ledger for Commitment Control setup enables you to take advantage of other General Ledger processes, such as revaluation, ChartField translation, allocations, and summary ledgers. However, be aware that Commitment Control ledgers and ledger groups do not function in all respects as do General Ledger detail ledgers and ledger groups.
Commitment Control documentation often uses synonymously the terms amount type and ledger.
Also, the Commitment Control Ledger Data table at times is referred to as the Commitment Control ledger or budget ledger. It is important to remember these distinctions, as well as the synonymous use of these terms when a particular aspect of Commitment Control budget is being discussed.
Ledgers defined by the Commitment Control ledger template can have different sets of ChartFields than do General Ledger detail ledgers. These can include General Ledger and Projects ChartFields, as well as the Budget Period ChartField.
