The Project Progress Process
The PeopleSoft system integrates with PeopleSoft Project Costing to eliminate duplicate data entry for revenue that is tied to percent complete plans. You can automatically populate the percent complete for revenue plans in PeopleSoft Contracts with a value generated in PeopleSoft Project Costing. This value comes from the project or project and activity combination in PeopleSoft Project Costing. You determine which auto populate method to use on the Revenue Plan page. After choosing an auto populate option, you can set up a run control that allows the processing of one or more plans at a time.
You must have already linked your amount-based contract lines to a project or project and activity combination in order to have the project progress options available to you on the Revenue Plan page.
Related Topics
