The Project Progress Process
PeopleSoft Contracts integrates with PeopleSoft Project Costing to eliminate duplicate data entry for billing that is tied to project progress or milestones. You can automatically populate the percent complete for billing plans in PeopleSoft Contracts with a value that is generated in PeopleSoft Project Costing. This value comes from the project or project and activity combination in PeopleSoft Project Costing. You determine which autopopulate method to use on the Billing Plan - Events page. After choosing an autopopulate option, you can set up a run control that allows the processing of one or more plans at a time.
