PeopleSoft Cost Management Reports: A to Z
This table lists the PeopleSoft Cost Management reports sorted alphanumerically by report ID. If you need more information about a report, refer to the report details at the end of this topic:
| Report ID and Report Name | Description | Navigation | Run Control Page |
CES5001 Update Production Costs |
Lists all updates to the frozen standard costs that are used in production and associated with a specified cost type and version. Sort by standard cost group and item ID, descending variance, or item ID. When applied, these costs update the production standard cost record and revalue inventory by using the standard cost method in all storage areas including stores, inspection, finished goods, and work in process (WIP), as well as in process inventory. Options include printing the report without revaluing inventory, revaluing inventory and printing the report, or revaluing inventory without printing a report. The Report Only option previews the financial impact of the standard cost changes without affecting the current standard costs. |
RUN_CES5001 |
CES6000 Compare Cost Versions |
Use to compare the item costs that are derived from a regular cost version to those of an engineering or simulation cost version, to analyze the impact of engineering changes to an item's cost, or to view the cost impact of changing the bill of materials (BOM) or process. If you want to analyze the impact of BOM, routing, labor, machine, or overhead rate changes on item costs, you can roll up costs for a separate cost type and version. To see the impact of the changes, you can compare two different cost types for an item or two versions of a single cost type. |
RUN_CES6000 |
CMS1000 Average Cost Adjustments |
Reports adjustments and updates to perpetual average costs and retroactive perpetual average costs. The report includes adjustments entered directly on the Adjust Average Cost page (CM_COST_ADJ) and the Adjust Retro Costs page (CM_COST_ADJ_RETRO) as well as the purchase price variance (PPV) and exchange rate variance (ERV) updates that occur automatically when the Transaction Costing process runs. |
RUN_CMS1000 |
CMS2000 Item Cost Profiles |
Lists cost profiles for items that are in a selected business unit. |
RUN_CMS2000 |
CMS2001 Overridden Cost Profiles |
Lists business unit items where the cost profile is different from what is specified in the cost profile group. |
RUN_CMS2001 |
CMS2002 Item without Profiles |
Lists business unit items that are not associated with a cost profile. |
RUN_CMS2002 |
CMS2010 On Hand Value Report |
Lists on-hand quantity and value at the summary or detail level. Can be used for items with any cost method. The report can calculate WIP as of any point in time and is accurate to the extent that the Transaction Costing, Accounting Line Creation, and Journal Generator processes have been run. The report can also store snapshots of previously generated report data for historical reporting. Select the items that are to appear on the report by business unit, cost book, cost profile, item information, or accounting period. In addition, you can use it to compare the on-hand value by using floor and ceiling costs or last price used. |
RUN_CMS2010A RUN_CMS2010 RUN_CMS2011 |
CMS2015 Movement by Receipt |
Summarizes depletions, and shows on-hand quantity and value by receipt line. The unit costs that are used to calculate receipt and depletion costs reflect costs at transaction time. |
RUN_CMS2015 |
CMS2016 Movement by Depletion |
For each depletion line, this report prints the receipt that the system uses to deplete that transaction, by business unit, book, and item. The depletion cost is calculated based on the cost at processing time. The report does not display on-hand quantity or value. |
RUN_CMS2016 |
CMS2018 WIP Value History Report |
Lists the inventory value of all actual WIP costs at a summary or detail level. The report can calculate WIP as of any point in time and is accurate to the extent that the Transaction Costing, Accounting Line Creation, and Journal Generator processes have been run. The report can also store snapshots of previously generated report data for historical reporting. Select the items that are to appear on the report by business unit, cost book, cost profile, item information, or accounting period. Note: The WIP Value History report is only for production with items using a cost method of actual or perpetual average. For production using a cost method of standard, the WIP Value Inventory Report (SFS1000) can be used to review WIP Value for standard-costed assemblies. |
RUN_CMS2018A RUN_CMS2018B RUN_CMS2018C |
CMS3000 Estimated vs. Actual Landed Costs |
Lists the purchase price variances (PPV) for landed cost components. |
RUN_CMS3000 |
CMS3010 Total Purchase Variance |
Lists the purchase price variances (PPV) and exchange rate variances (ERV) for landed cost components. |
RUN_CMS3010 |
CMS3020 Standard Purchase Variance |
For frozen standard items only, lists the purchase price variances (PPV) that are recognized at receipt of the item. |
RUN_CMS3020 |
CMS9010 On Hand Balance Validation |
Verifies that the quantities tracked by PeopleSoft Cost Management are the same as the quantities tracked by PeopleSoft Inventory. This report serves as an audit tool to help verify that every change to PeopleSoft Inventory quantity balances has been accounted for in the PeopleSoft Cost Management system. |
RUN_CMS9010 |
ENS1011 Costed Routing Report or Costed Eng Routing Report |
Displays costs by item routing, including conversion and overheard conversion costs that are attached to the item routing by task or work center. Material costs can also be displayed if a BOM code is entered. Enter unit, item ID, cost type, cost version, routing code, and BOM code. All routing codes and BOM codes are available; the Cost Rollup process does not have to be run to retrieve the costs. |
RUN_ENS1011 |
INS7000 Inventory Value |
Provides realtime, on-hand quantities and values for items using standard costing or perpetual weighted average costing. This report is not intended for actual cost items. |
RUN_INS7000 |
INS7050 Accounting Register |
Lists accounting transactions with item information, transaction dates, and the posted ChartFields. |
RUN_INS7050 |
INS7100 Transaction Register |
Lists all transactions by item ID. |
RUN_INS7100 |
SFS1000 WIP Inventory Value |
(standard cost items only) Lists the value of all WIP items by production type sorted by account, item ID, or production area. Lists the value of all items that are in various stages of assembly, including material that is consumed from the WIP locations or issued as part of a production kit. This report also lists labor, machine, overhead, and outside processing costs that are incurred up to the point that the WIP inventory value report is run. This report does not include the costs of any scrapped components or assemblies, or assemblies that are completed to stock. You can select owned items and consigned items. Includes a line for waste costs. |
RUN_SFS1000 |
SFS1100 Close Production |
Closes production schedules or production IDs, and calculates the variances that are incurred. Use the Report Only mode to view the production that can and cannot be closed as well as the variances that can be generated as a result of an accounting close. Combining numerous sort options assists in narrowing down the production close information that is reported. |
RUN_SFS1100 RUN_SFS1100A |
SFS1200 Reopen Production |
Enables production to be reopened to record additional completions, material consumption, or actual hours. Use the Report Only mode to provide a preview of the financial impact of reopening production without creating reversing entries. Combining numerous sort options assists in narrowing down the production reopen information that is reported. |
RUN_SFS1200 |
SFS1500 Production Variance Report |
Lists variances for production IDs or production schedules for a specified production due date and shift and above a minimum monetary amount. Variances include configuration, usage, component yield, lot size, routing process, rework, teardown, production mix variance, and outside processing. |
RUN_SFS1500 |
SFS1600 Potential Production Variance Report |
Lists potential production variances that exist in production above a monetary amount before closing for accounting production IDs and schedules. The report can be generated when in a production status of in process, pending complete, complete, and closed for labor. Variances include configuration, usage, component yield, lot size, routing process, rework, teardown, production mix variance, and outside processing. |
RUN_SFS1600 |
SFS2005 Efficiency and Utilization Report |
Details efficiency variances and utilization by work center. Within work centers, the production ID or schedule that utilizes the work center is specified. Efficiency variance is the difference between the actual hours that are expended for an operation and the earned hours for the operation. Utilization compares the available hours for a work center to the actual hours that are recorded for a work center. |
RUN_SFS2005 |
CM_EOM_VALUE Inventory Cost Balancing Report |
Compares changes in Inventory values [item and account level] to those on Inventory distribution accounting lines, to identify variances, for a given accounting period. |
CM_EOM_VALUE_1 CM_EOM_VALUE_2 CM_EOM_VALUE_3 |
