Maintaining Users
To set up supplier users, use the Define Supplier User (UM_DISTR_INTVND) component.
Once your supplier application administrators define them, your suppliers' administrators can perform their own user maintenance.
Pages Used to Maintain Users
Maintain Supplier Information - Setup User Page
UM_DISTR_VNDR_INT
Internal users with the Supplier Application Administrator role can create external administrators, give other internal users access to supplier IDs, and create or update suppliers' users.
Security - Setup User Page
UM_DISTR_VNDR_EXT
External supplier administrators can create and maintain their own supplier users and give them access to supplier data.
Add Supplier Page
EXT_VND_SELECT
Suppliers can add new suppliers to be assigned to suppliers' users.
Define Supplier User Page
VENDOR_USER
Associate users with suppliers.
Use the Define Supplier User page (VENDOR_USER) to associate users with suppliers.
Navigation:
Internal Users: Suppliers, and then Supplier Information, and then Add/Update, and then Define Supplier User
This example illustrates the fields and controls on the Define Supplier User page. You can find definitions for the fields and controls later on this page.
To set up supplier users:
  1. Enter logon information, completing these fields in particular:
    Field or Control Description
    Account Locked Out?
    Select to disable this user's access to the PeopleSoft system.
    Access Profile Symbolic ID
    Each user ID has an encrypted access profile. Select a symbolic ID to use as a search key or intermediary between the user ID and the access ID.
    See the product documentation for PeopleTools: Security Administration.
    Language Code
    Select a base language for the user.
    Rate Type
    PeopleSoft MarketPay uses this field.
  2. Assign roles to the user.
    To set up security for external users, you must assign the PeopleSoft Supplier Application Administrator role to internal users. See Establishing Self-Service Security for Suppliers.
  3. Associate (existing) supplier IDs to the user. If suppliers have registered online, then supplier IDs are automatically associated to the user ID.
    Each user ID can be associated with one or multiple supplier codes. This enables the user to view and, with the proper permissions, maintain data for the associated suppliers. When the user logs in to PeopleSoft eSupplier Connection, the system determines to which supplier the user is associated. If the user is associated with multiple suppliers, the Select Supplier page lists the suppliers.
    Click the Contacts link to view the list of supplier contacts. The Supplier Contacts page also displays each contact's Name, Phone Number, Type, and Email. The Contacts link is displayed in the Supplier Access grid only if the Supplier has at least one Contact defined in the Supplier Master Contact tables. Additionally, the Contact must have a Max Effective Date that is less than or equal to the current date and an Active Effective Status.
  4. Associate bidder IDs to the user. Only the active bidder IDs are displayed for selection. Inactive or Unapproved bidders are not displayed.
    To view the Bidder Access details, you need to select the Allow Supplier User to Access Multiple Suppliers and Bidders check box on the strategic sourcing installation.
    When you convert a bidder to a supplier or post award for events, the bidder ID is set to Inactive. This generates a new supplier ID. In such cases, the bidder is automatically removed from the Bidder Access grid. The corresponding supplier ID will be added to the Supplier Access table.
Use the Maintain Supplier Information - Setup User page for external users to associate user IDs with supplier codes.
Navigation:
External users: Maintain Supplier Information, and then Manage User Profiles
The values on this page duplicate the fields on the Define Supplier User page, but they apply to external users only and are designed for the casual self-service user.
