Understanding PeopleSoft eSupplier Connection Pagelets
PeopleSoft eSupplier Connection provides portal pagelets for your corporate intranet or extranet home pages. These pagelets provide access to key data and transactions within PeopleSoft eSupplier Connection for use in supplier portal registries.
You and the suppliers can personalize the portal homepage by adding the pagelets that the suppliers need. Standards PeopleSoft role-based security ensures that users can access only the pagelets appropriate to their roles.
Suppliers can configure their portal home page with three narrow columns or one narrow and one wide column. Some pagelets have both a narrow and a wide version, each with its own object name. When you see two object names for a pagelet, the first one refers to the narrow version.
| Field or Control | Description |
Click to refresh the pagelet data. |
Click to customize the pagelet. |
You can also design your own pagelets when your installation includes PeopleSoft Applications Portal.
See the product documentation for PeopleTools: Portal Technology
