Setting Up PeopleSoft Lease Administration for the PeopleSoft ALM Portal Pack
This topic provides an overview of PeopleSoft Lease Administration for the PeopleSoft ALM Portal Pack and lists the page used to set up Lease Administration for the ALM Portal Pack.
Page Used to Set Up PeopleSoft Lease Administration for the PeopleSoft ALM Portal Pack
Load Pagelet Data Page
RUN_RE_PGLT_DATA
Run a process that creates summary data used by PeopleSoft Lease Administration pagelets in the PeopleSoft ALM Portal Pack.
Go to Set Up Financials/Supply Chain, and then Pagelets, and then Asset Lifecycle Management, and then Lease Administration, and then LA Portal Data Collector.
Understanding PeopleSoft Lease Administration for the PeopleSoft ALM Portal Pack
If you currently use PeopleSoft Lease Administration and want to use the PeopleSoft Lease Administration pagelets in the PeopleSoft ALM Portal Pack, you must schedule and run the Lease Administration Portal Data Collector Application Engine process (RE_PGLT_DATA). The Lease Administration Portal Data Collector process summarizes transaction data in order to improve response times when viewing the pagelets. The data is stored in summary tables and is displayed on pagelets according to your personalized settings. While the Lease Administration Portal Data Collector greatly improves response times for reading the data, it also imposes limitations on when changes to the transaction data are reflected in the pagelets. Changes in the transaction data are not reflected in the pagelets in real time. You must periodically rerun the Lease Administration Portal Data Collector process to refresh the pagelets. Oracle recommends setting up a recurring job to execute the Lease Administration Portal Data Collector on a periodic basis. How often you run the collector process depends on a number of factors such as:
  • How quickly you need the data updated.
  • How much data you have in the system—the longer your system operates, the more data has to be summarized, hence the longer the data loader process can take to execute.
  • How many system resources are available to your process scheduler.
