Setting Up PeopleSoft Receivables for the PeopleSoft Financials Portal Pack
This topic provides an overview of setup and lists the page used to set up PeopleSoft Receivables for the PeopleSoft Financials Portal Pack.
Page Used to Set Up PeopleSoft Receivables for the PeopleSoft Financials Portal Pack
Page Name Definition Name Usage and Navigation
Update Pagelet Statistics Page
AR_CFOLOAD_RQST
Run a process that creates summary data used by PeopleSoft Receivables pagelets in the PeopleSoft Financials Portal Pack. Select the currency and rate type used to display the data on pagelets.
Go to Accounts Receivable, and then Receivables Update, and then Update Pagelet Statistics.
Understanding Setup
If you are currently using PeopleSoft Receivables and want to use the PeopleSoft Receivables pagelets in the PeopleSoft Financials Portal Pack, you must schedule and run the Receivables Update Pagelet Statistics Application Engine process (AR_CFOLOAD). The Update Pagelet Statistics process summarizes transaction data and converts different currency amounts to the currency specified on the run control. PeopleSoft Receivables stores the data in summary tables and displays it on pagelets based on your personalized settings.
