Archive Templates
When you archive journals and ledgers, you can select one of the delivered system data templates or, if necessary, create a new archive template definition. Each archive template definition includes one or more archive object definitions and corresponding archive query definitions. You can also specify in the archive template preprocessing and postprocessing application engine processes.
The following archive template definitions are delivered as system data:
Archive Template Archive Object Pre- or Postprocesses
GL_JRNL
GL_JOURNAL
GLARC_JRL1S (preprocess)
GLARC_JRL2S (postprocess)
GL_LED
GL_LEDGER
GLARC_LED1S (preprocess)
GLARC_LED2S (postprocess)
GLADB
GL_LEDGER_ADB
GLADBMTD
GL_LED_ADB_MTD
GLADBQTD
GL_LED_ADB_QTD
GLADBYTD
GL_LED_ADB_YTD
