Preprocesses and Post Processes
This is a list of the pre- and post- Application Engine processes that are delivered as system data and that you can use as is or modify to meet different requirements:
| Process Name | Object Name | Description |
Journal Archive Selection Preprocess |
GLARC_JRL1S |
The process validates the journal archive selection and generates warnings or errors:
Journal Archive Selection Post Process |
GLARC_JRL2S |
The process generate statistics for the archived journals in the process monitor. You can see data statistics recorded in the archive process in the process monitor:
Ledger Archive Selection Preprocess |
GLARC_LED1S |
The process validates the ledger archive selection and generates errors if:
Ledger Archive Selection Post Process |
GLARC_LED2S |
The process generate statistics for the archived ledgers in the process monitor. You can see data statistics recorded in the archive process in the process monitor:
