Common Elements Used in the General Ledger WorkCenter
Most WorkCenters have a similar look and are configured the same. Some icons are developed in PeopleTools and appear on WorkCenter pages.
For additional information about common elements in FSCM WorkCenters, see Application Fundamentals: Common Elements Used in WorkCenters.
Elements that are specific to General Ledger are:
| Field or Control | Description |
(Actions) |
Select an action to apply to the selected rows. Actions are specific to the selected pagelet or exception. Some examples include:
Action options for each user can be different based on their privileges. |
