Pages Used with the PeopleSoft Fluid General Ledger WorkCenter
General Ledger WorkCenter Tile
NA
Access the General Ledger WorkCenter page in PeopleSoft Fluid.
General Ledger WorkCenter Page (Fluid)
NA
Access frequently-used areas according to your role and security using the PeopleSoft Fluid User Interface.
General Ledger WorkCenter - My Work Page (Fluid)
NA
View and take action on frequently-used components and be alerted to the transactions that require your attention.
General Ledger WorkCenter - My Approvals Page (Fluid)
NA
View and approve pending transactions.
General Ledger WorkCenter - Links Page (Fluid)
NA
Access frequently-used links to components such as Tree Manager, Process Monitor, Open Period Updates, Spreadsheet Journal Import, and so on.
General Ledger WorkCenter - Queries Page (Fluid)
NA
Access Query Manager, public queries, and private queries, without leaving your WorkCenter.
General Ledger WorkCenter - Reports/Processes Page (Fluid)
NA
Access frequently-used report and process run controls.
