Configuring Integration Broker for ChartField Integration to Fusion Accounting Hub
In order to publish the ChartField values from PeopleSoft to Fusion, you must configure Integration Broker as follows:
  1. Verify that the RIDCTARGET connector is listed and the Local gateway is active.
  2. Activate the delivered service operation, FAI_UCM_UPLOAD.
  3. Activate the delivered node definition, UCM_NODE.
  4. Verify External System Setup.
PeopleTools release must be 8.53.06 or later to accommodate the ChartField value file transfer. This delivers the RIDCTARGET connector.
To activate the integration for publishing the PeopleSoft ChartField values to Fusion Accounting Hub:
  1. Verify the Integration Broker Gateway is Active and Configured for the Integration
    Access the Gateways page (PeopleTools, Integration Broker, Configuration, Gateways).
    Verify that the RIDCTARGET connector is listed. Click the Ping Gateway button to ensure the Local gateway is running and connectors are loaded – status should be Active.
  2. Activate the service operation
    Access the Service Operation, FAI_UCM_UPLOAD, (PeopleTools, Integration Broker, Integration Setup, Service Operations, General).
    • Make sure the Active check box is selected on the General page.
    • Click the Service Operation Security link and verify that the appropriate security is granted by Permission List as according to your organization’s security policies
  3. Activate the node definition
    Access the Node Name, UCM_NODE, (PeopleTools, Integration Broker, Integration Setup, Nodes, Node Definition).
    • Verify that the Active Node check box is selected. If not, select it and save the page.
    • Navigate to the Routings page and confirm that the UCM_NODE_OUTPUT routing is active.
    See also PeopleSoft PeopleTools PeopleBook: Integration Broker, -Managing Integration Gateways.
  4. Complete the UCM Server Information section of the External System Setup page.
