Mapping the External System to PeopleSoft
Use the External System Setup component (FAI_EXTSYS_SETUP) to map any external system (third party) to PeopleSoft General Ledger. Although this component is delivered preconfigured for Fusion Accounting Hub, you can map as many external systems as your organization requires.
