GLJE Entry Event Process
The GLJE Entry Event process is used for most types of entry event journal entries. When an entry event code is associated with the GLJE Entry Event process, you can generate additional debit and credit entries—beyond the entries that the user entered by the Journal Edit process—for accounting.
In a journal that uses the GLJE Entry Event process, the account from the entry event code appears by default in the first journal line unless the entry event code is set up for IU processing as well. When you run the Journal Edit process (GL_JEDIT), the Entry Event Processor runs automatically during the edit process, generating the additional entry event lines.
  • Run the Journal Edit process.
    The Journal Edit process runs the Entry Event Processor.
  • Run the Budget Processor if commitment control is enabled for the business unit and ledger group.
  • Post to the General Ledger actuals ledger.
