Integrating General Ledger with Commitment Control using ADS
These Application Data Sets are delivered to move setup data between databases.
This table provides the Application Data Sets (ADS), their usage, and the records for each data set:
When you copy dataset definitions, the data referenced within the copied datasets must exist within the database to which you are copying the Data Set definitions. For example, the tree definitions and ChartField values that are referenced within the Budget Definitions should be current in your source and target databases.Table 8-1 GL to CC ADS
| Delivered ADS Name | ADS Usage | Record Names |
KK_ASSOC_BDS |
This data set contains the records that store associated expense and revenue budget details. |
Driven by : BUS_UNIT_TBL_GL KK_REV_XREF KK_EX_XREF |
KK_ATTRIBUTES |
This data set contains the records that store Commitment Control budget attributes. |
Driven by: BUS_UNIT_TBL_GL KK_BD_ATTRB_MST KK_BD_ATTRIB KK_BD_ATTRIB_BP |
KK_BD_BP |
This data set contains the records that the budget period transfer process sets for closing. |
KK_BP_XFER_SET KK_BP_XFER_LANG KK_BP_XFER_LINE |
KK_BU |
This data set contains the records that store the association between Actuals ledger groups and Commitment Control ledger groups. |
BUL_CNTL_BUD |
KK_BUDGET |
This data set contains the records that store Commitment Control budget definitions. |
KK_BUDGET_TYPE KK_BT_BP_CAL KK_BT_BP_VALUE KK_BD_OFFSET KK_BD_SETID KK_EXP_CF_SETID KK_EXP_CF_VALUE KK_SUBTYPE KK_KEY_CF KK_FILTER_SETID KK_FILTER KK_ACT_TYPE_SET KK_EX_ACCT_TYPE KK_INCL_ACCTS KK_BUD_TYP_LANG KK_EX_ACT_SETID KK_EX_ACCT_VAL KK_SRC_TRAN KK_TRX_OFFSET |
KK_CLOSE_DEFN |
This data set contains the records that store the Commitment Control close budget definitions. |
KK_CLOSE_DEFN KK_CLOSE_OFFST2 KK_CLOSE_FR_ANC KK_CLOSE_LINE KK_CLOSE_FROM KK_CLOSE_TO KK_CLOSE_OFFST1 KK_CLOSE_TO_ANC KK_CLOS_DF_LANG |
KK_CLOSE_SET |
This data set contains the records that store the Commitment Control close budgets sets. |
KK_CLOSE_SET KK_CLOSE_LEDGRP KK_CLOSE_BALSRC KK_CLO_SET_LANG KK_CLO_SET_RULE |
KK_JRNL |
This data set contains the records that store Commitment Control budget journals. |
KK_BUDGET_HDR KK_BUDGET_LN |
