Integrating General Ledger with PeopleSoft EPM Budgeting
EPM defines and initiates the General Ledger to PeopleSoft Enterprise Performance Management Budgeting integration using the ETL tool. This process is initiated from the PeopleSoft Budgeting application.
Refer to the PeopleSoft Budgeting documentation for details concerning how to use this feature.
Page Used to Integrate General Ledger with PeopleSoft EPM Budgeting
Importing Budgeting Data
BP_RUN_CNTL_LEDGER
Imports data from EPM Budgeting. See Importing Data from EPM Budgeting.
See PeopleSoft Budgeting Documentation, "Integrating with PeopleSoft Financial Management Applications," Using Informatica Powermart ETL and Data Loader Utility, and Importing Data Into General Ledger
Use the Importing Budgeting Data page (BP_RUN_CNTL_LEDGER) to imports data from EPM Budgeting.
Navigation:
Set Up Financials/Supply Chain, and then Product Related, and then Budgeting, and then Import Budget Ledger
See PeopleSoft Planning and Budgeting Documentation, "Integrating With Other Applications"
