Multibook Ledgers Using Entry Events
To enter entry events for multibook journals:
  1. Enter one side of the journal entry by selecting an entry event code for a ledger group that contains multiple ledgers and for which the Keep Ledgers in Sync check box is selected.
  2. Run the Journal Edit process.
    When you enter the journal line, you typically enter only one side of the journal if you are using entry events for the GLJE Entry Event process. The Journal Edit process generates the additional entry event lines for the primary ledger. It also matches journal lines for all secondary ledgers within the ledger group using the same entry event code. This is a multibook journal entry.
    If the journal is from an external source and does not already have secondary ledger lines, Journal Edit process creates the secondary ledger lines and calls the Entry Event Processor to create the entry event lines.
  3. Continue to process and post the multibook journal.
