Pages Used in the Integration between PeopleSoft General Ledger and Fusion Accounting Hub
| Page Name | Definition Name | Usage and Navigation |
FAH Accounting Entries Page |
FSAH_ACTG_DRILL |
Go to to drill from PeopleSoft inquiry pages to review Fusion journals. |
Fusion Accounting Hub - Value Set Mapping Page |
FUS_ASGN_CFVS |
Go to to map the PeopleSoft SetID and ChartField combinations to the Fusion Value Set Codes. Run the FUS_CFANLYZR process to initially load the value-set staging table that is used in the data conversion from PeopleSoft to Fusion. |
