Understanding the Integration between PeopleSoft General Ledger and Fusion Accounting Hub
PeopleSoft General Ledger provides the ability to integrate journal entries with Oracle Fusion Accounting Hub. As such, PeopleSoft users can take advantage of Fusion Accounting Hub functionality, such as the embedded Hyperion Essbase features, while continuing to use PeopleSoft General Ledger as the system of record. After configuring the delivered setup pages, you can transform and transfer PeopleSoft General Ledger journals to Fusion General Ledger journals and leverage the analysis and reporting tools within Oracle’s Fusion Accounting Hub.
This integration enables you to perform the following functions:
  • Map PeopleSoft control data such as business units and ledgers to Fusion ledgers.
  • Upload and convert chart of accounts data from PeopleSoft to Fusion.
  • Transfer journals from the PeopleSoft General Ledger to the Fusion General Ledger.
  • Drilldown from Fusion journal line detail to PeopleSoft journal details.
  • Drill from PeopleSoft to review Fusion journals.
See Article ID 1365971.1 on My Oracle Support website to access the PeopleSoft General Ledger Integration to Oracle® Fusion Accounting Hub 1.0.1 Implementation Guide and the related PeopleSoft Documentation Update.
Pages Used in the Integration between PeopleSoft General Ledger and Fusion Accounting Hub
Pages primarily used in this integration can be found in General Ledger, and then Fusion Accounting Hub. All pages are fully documented and can be found in Article ID 1365971.1 on My Oracle Support website. Download related documents.
