Setting Up PeopleSoft General Ledger Reporting
Page Used to Set up PeopleSoft General Ledger Reporting
| Page Name | Definition Name | Usage |
Application Fundamentals: Installation Options - Overall Page |
INSTALLATION_FS1 |
Configure installation information and indicate how you want to use cross-application features. Two fields on this page are used when flattening data for General Ledger Reporting. |
Installation Options – Overall Page
Use the Installation Options – Overall page (INSTALLATION_FS1) to configure installation information and indicate how you want to use cross-application features.
Navigation:
These fields are used to flatten data for General Ledger Reporting:
| Field or Control | Description |
Use Flatten Tree Data |
Click this link to access the Tree Flattener Options page where you can select these options: General Ledger Reporting: Select to populate flattened tree data in a format that is usable by General Ledger Reporting. This check box must be selected if you are using General Ledger Reporting feature. Detail List: Select so that GL batch processes use the flattened tree data to improve performance. |
Maintain Chartfield EDR Data |
Select this check box to indicate that ChartField effective date range data is to be maintained by Online ChartField components. This option is required if the Use Flatten Tree Data option is selected. |
For technical information about setting up and using General Ledger Reporting, see Oracle Red Paper - General Ledger Reporting on My Oracle Support.
