Flattening Data for General Ledger Reporting
Follow these steps to flatten data for General Ledger Reporting:
  1. Submit the Business Unit SetID mapping request process.
  2. Submit the Date Flattener request process.
  3. Submit the Period Flattener Request process.
  4. Submit the Materialized View Maintenance Request process.
    This step is only applicable if you are using PeopleTools 8.54 or higher.
  5. Configure the default Tree Setup.
For technical information about setting up and using General Ledger Reporting, see Oracle Red Paper - General Ledger Reporting on My Oracle Support.
