Setting Up Trees for DATA Act Reports
This topic discusses how to set up PeopleSoft Trees for DATA Act reports.
Pages Used to Set Up Trees for DATA Act Reports
Tree Manager Page
PSTREEMGR
Set up Account Rollup, Object Class, and Disaster Emergency Fund Code trees
For general information about trees in PeopleSoft, see the product documentation for PeopleTools: Tree Manager.
Tree Manager Page
Use the Tree Manager page (PSTREEMGR) to set up Account Rollup, Object Class, and Disaster Emergency Fund Code trees.
Navigation:
Tree Manager, and then Tree Manager
Account Rollup Tree
The following example shows the Account Rollup Tree on the Tree Manager page. This tree translates GL accounts to the 6-digit USSGL account values required by Treasury. In addition, this tree specifies all accounts that are reportable.
This tree is required even if your agency currently uses 6-digit General Ledger accounts.
This example illustrates the fields and controls on the Tree Manager page for the Account Rollup Tree.
Account Rollup Tree in Tree Manager
Object Class Tree
This example shows a partial Object Class tree. Because the PeopleSoft ChartField designated for Object Class is Class (as defined on the Federal Object and Program Trees page), this tree is based on the Class ChartField. This tree translates Class into the appropriate Federal Object Class code for use on the bulk file and identifies which Object Classes are reportable.
This tree is required even if no translation is necessary.
This example illustrates the fields and controls on the Tree Manager page for the Object Class Tree.
Object Class Tree in Tree Manager
Disaster Emergency Fund Code Tree
This tree translates the values in the field defined for Disaster Emergency Fund Code.
This example illustrates the fields and controls on the Tree Manager page for the Disaster Emergency Fund Code Tree.
Tree Manager - Disaster Emergency Fund Code
