Submitting Journals for Approval Using WorkFlow Based on the Approval Framework
The following diagram shows the approval process using AF from submitting a journal entry through the checking of the rules by priority, definition name, and effective date; the checking of criteria for paths and steps; and the routing of approval requests by worklists and email.
Submitting Journals through Approval Process Using Approval Framework
Submitting journals through the approval process
