Using General Ledger Navigation Collection
PeopleSoft General Ledger provides a custom navigation page, which contains folders that provide access General Ledger Classic pages . The General Ledger Fluid tile can be added to any homepage using the Personalize Homepage option.
Pages Used to Navigate General Ledger Using PeopleSoft Fluid
General Ledger Tile
PS_CHART_GENERAL_L_FL
Access General Ledger navigation collections.
General Ledger (navigation collection)
EP_GL_GENERALLEDGERNC_FL_GBI
Access frequently used pages.
General Ledger Tile
Use the General Ledger tile (PS_CHART_GENERAL_L_FL) to access General Ledger navigation collections.
Navigation:
You can add the delivered tile as part of a homepage or any suitable location.
This example illustrates the fields and controls on the General Ledger Tile.
General Ledger tile
To add this tile to a homepage, access the desired homepage. Select the Actions List button, Personalize Homepage, click the Add Tile button, click FSCM Navigation Collections, select General Ledger, and then click the Save button.
Use the General Ledger (navigation collection) page (EP_GL_GENERALLEDGERNC_FL_GBI) to access frequently used pages.
Navigation:
Select the General Ledger tile.
This example illustrates the fields and controls on the General Ledger (navigation collection).
The General Ledger navigation collection allows users to access frequently used components from one location. When you expand each category in the left side of the page and select an option, the right side of the page displays the Find an Existing Value and Add a New Value search for the selected option. For example, when you expand General Ledger Design and select Business Unit Definition, the system take you to the Find an Existing Value and Add a New Value search for General Ledger Definition.
Administrators can edit these categories by navigating to the Structure and Content page. (PeopleTools, Portal, Structure and Content, Portal Objects, Navigation Collections, General Ledger.
This table lists the expandable sections on the left side of the page and the options within each section:
Section Section Options
  • Business Unit Definition
  • Ledgers For A Unit
  • ChartField Design
  • ChartField Values
  • Define ChartField Attributes
  • ChartField Request
  • Tree Manager
  • Combo Edit Rules
Multi-Currency
  • Market Rates
  • Ledger Groups
  • Revaluation Step
  • Translation Rules
  • Translation Steps
Commitment Control
  • Budget Definitions
  • Enter Budget Journals
  • Budgets Overview
Journal Transactions
  • Journal Entries
  • Define Standard Journals
  • Create Standard Journals
  • Review Standard Journals
  • Spreadsheet Journals
  • Journal Generate
  • UnPost Journals
Allocations
  • Define Allocation Step
  • Define Allocation Group
  • Request Allocation
Consolidations
  • Tree Manager
  • Elimination Sets
  • Minority Interest Sets
  • Subsidiary Ownership
  • Consolidation Ledger Sets
  • Consolidation Set
  • Consolidation Dashboard
Reconciliations
  • GI Subsystem Recon Inquiry
  • Configure Reconciliations
  • Reconciliation Rule
  • Assign Reconciliations
  • Reconciliation Workbench
Close
  • Year End Closing Rules
  • AP Posting Control by Group
  • Open Period Update
  • Open Periods Mass Update
  • Request Year End Close
Reports and Analysis
  • nVision Report Request
  • Ledger Inquiry
  • Inquiry across Ledgers
  • Journal Inquiry
  • Ledger Period Comparison
Additional Setup
  • Calendar Builder
  • Accounting Entry Templates
  • Define InterUnit Templates
  • Define InterUnit Pairs
  • Setup ChartField Value Sets
  • Journal Generator Template
  • Enable Audit Logging
  • Approval Process Setup
  • TimeSpans
GL WorkCenter
(none)
