Using Non-Shared Tables
Use PeopleTools temporary tables.
Use GL non-shared tables.
Set up GL non-shared tables.
Pages Used to Set Up GL Non-Shared Tables
| Page Name | Definition Name | Usage |
Shared Table Statistics Page |
TEMP_TBL_STATS |
Access a log containing each time the process used a shared base working table because a non-shared table was not available. |
Non-Shared Table Maintenance Page |
NONSHARED_TBL_ASGN |
Add, delete, or modify non-shared tables. |
Define Batch Truncate Threshold Page |
DELETE_LIMIT_ASGN |
Specify delete or truncate threshold for Application Engine Processes. |
Non-Shared Table Truncate Threshold |
NST_ASGN_TRTHRS |
Specify delete or truncate threshold for COBOL processes. |
Using PeopleTools Temporary Tables
PeopleTools provides a feature that allows applications to dedicate a specific instance of a PeopleTools temporary table for each GL Application Engine program run. This concept is similar to the GL non-shared table design in that it drastically reduces the risk of table contention. This feature is supported in some of the General Ledger Application Engine processes that use the PeopleTools temporary tables. These General Ledger Application Engine processes use the PeopleTools temporary tables:
Journal Edit.
Journal Post.
Combination Editing.
Allocation Copy Utility.
Inter/IntraUnit Common Processor.
Journal Generator.
ADB Post and Calculation.
Budget Processor.
Allocations.
Summary Ledger Build.
Multicurrency (COBOL and Application Engine)
General Ledger Year End Close (COBOL and Application Engine)
See PeopleTools 8.5x Documentation: PeopleSoft Application Engine, "Using Temporary Tables"
Using GL Non-Shared Tables
Application Engine and COBOL SQL processes use GL non-shared tables to increase performance.
The records PS_LEDGER (ledger) and PS_JRNL_LN (journal line), which include the PS_JRNL_HEADER (journal header) record are the most heavily accessed records. While these two records are the focus of this topic, you can apply the same techniques to any record.
Several GL Application Engine and COBOL SQL processes use base working tables to process large volumes of temporary data. Base working tables are shared working temporary tables that can be used by more than one program to process temporary data. You can potentially hamper performance if you run concurrent processes that use the same base working table.
To increase performance, these processes use GL non-shared tables in place of the shared working tables:
Closing.
Journal Posting.
Ledger Load.
MultiCurrency.
Open Item Accounting.
GL non-shared tables are defined by appending the non-shared table version number, TEMP_TBL_NUM, from table TEMP_TBL_ASGNM to the base working table TEMP_TBL_NAME. Only the process that reserves the non-shared table can process transactions against that table.
The General Ledger Application Engine and COBOL SQL processes use table TEMP_TBL_ASGNM to identify and reserve a non-shared table. This table defines the fields in the TEMP_TBL_ASGNM table.
| Column | Description |
TEMP_TBL_NAME |
Base working table name. |
TEMP_TBL_NUM |
Non-shared table version number. |
IN_USE_SW |
Indicator to specify whether the non-shared table is in use. |
PROCESS_INSTANCE |
The process instance of the process that has the table reserved. |
Process for Assigning GL Non-Shared Tables
The process first determines if a non-shared table exists by matching the base working table name (shared table) of the processes to the base working table name in TEMP_TBL_ASGNM that has the IN_USE_SW indicator set to N:
If a non-shared table is available, it reserves it.
The process reserves the non-shared table by updating the IN_USE_SW indicator to Y in the TEMP_TBL_ASGNM table. No other process can use the non-shared table as long as the IN_USE_SW indicator is Y. The process updates the PROCESS_INSTANCE to identify which process has the non-shared table reserved.
If a non-shared table is not available, the process uses the base working table (instead of a non-shared table) and inserts a row into the TEMP_TBL_STATS table.
This table provides a way to monitor the load of base working tables. The statistics can be useful to decide whether more non-shared temp tables are needed. This table defines the fields in TEMP_TBL_STATS.
Column Description TEMP_TBL_NAME
PROCESS_INSTANCE
The process that attempted to reserve a non-shared table.
DATE_ASSIGNED
Process run date.
Setting Up GL Non-Shared Tables
The TEMP_TBL_ASGNM table is delivered with four non-shared tables for each base working table. If these do not meet your processing requirements, use the GL Non-Shared Table Maintenance page to add more non-shared table entries to TEMP_TBL_ASGNM.
Adding a Non-Shared Table
To add a non-shared table:
Determine if you need to create a non-shared table entry in TEMP_TBL_ASGNM.
On the Shared Table Statistics page, check the TEMP_TBL_STATS table to determine if the usage of the base working table justifies creating additional non-shared tables.
Create the GL non-shared table in PeopleSoft Application Designer.
Save the record definition from an existing non-shared table or the base working table. You should create the non-shared table from existing non-share tables rather than the base working table. Non-shared tables usually have less fields in the index structure that the base working table.
Create a GL non-shared table entry in TEMP_TBL_ASGNM using the GL Non-Shared Tables page.
Add a non-shared table for a custom base working table.
If you have created your own base working tables, add non-shared table entries to your Base Working Tables entries (repeat steps 1 to 3). Note that most non-shared tables do not require any unique indexes.
Use the Shared Table Statistics page (TEMP_TBL_STATS) to access a log containing each time the process used a shared base working table because a non-shared table was not available.
Navigation:
This log helps you to determine whether you need to create additional non-shared table entries in TEMP_TBL_ASGNM.
The process inserts a log in TEMP_TBL_STATS only if the non-shared table entries exist for the base working table in TEMP_TBL_ASGNM.
| Field or Control | Description |
Record (Table) Name |
Enter the name of the shared table whose statistics you want to view. |
Non-Shared Tables |
Displays the number of non-shared tables currently created. |
Table Name |
Displays the base working table name. |
Process Instance |
Displays the process that attempted to reserve a non-shared table. |
Job ID |
Displays the Job ID of the process that attempted to reserve a non-shared table. |
Date Assigned |
Displays the run date of the process that attempted to reserve a non-shared table. |
Use the Non-Shared Table Maintenance page (NONSHARED_TBL_ASGN) to add, delete, or modify non-shared tables.
Navigation:
You add instances of non-shared tables to the TEMP_TBL_ASGNM table so that the non-shared table is available for use by the batch processes.
To add a new instance of a GL non-shared table, enter its name in the Table Name field and click the Search button. All instances of that table are displayed. Click the Add icon to add a new instance.
Table Name |
Enter or select the name of the table that you want to maintain. Leave this field blank to view all tables available for maintenance. |
Process Instance |
Enter or select a specific process instance to maintain. Leave this field blank to view all process instances available for maintenance. |
Reset |
Click to reset the In Use field to No, which removes the check mark from the check box. Select Reset regularly for all tables, but make sure that no one is using the system. If a process aborts, the In Use flag remains set to Yes. In order to free the table for other processes, the you must reset the flag to No. |
WARNING:
If you reset a process instance while it is running, it can cause data integrity problems.
Reset does not clear the contents from a table. However, the table is cleared the next time it is assigned.
Table Name |
Displays the name of a non-shared table. You can select another name. |
Number |
Displays the instance number of the non-shared table. You can change this number. |
In Use |
Indicates whether the non-shared table is being used in a process. Click Reset to remove the check mark and change the selection to N. Note: See previous Warning before you select Reset. |
Process Instance |
Instance number of the batch process that has reserved this non-shared table. |
If you are using your own customized base working table, make sure the table name does not exceed 12 characters. The total character length of a table cannot exceed 15 characters, so you must allow for three characters for the non-shared table instances.
The following table identifies some of the General Ledger COBOL processes that use the General Ledger Non-Shared tables. The menu paths identify where the base working tables are assigned to the processes that support the use of non-shared tables, as well as the temp tables whose base table names are fixed.
In this table, if the temporary table is specified in the ledger template or some definition pages, the record name is listed in the Dynamic Working Tables column below; otherwise the record name is listed under the Fixed Working Tables column:
| Process | Menu Path | Dynamic Working Tables | Fixed Working Tables |
Closing |
Closing Tmp Closing RE Tmp Closing Account Tmp Closing Journal Header Tmp Closing Journal Line Tmp Closing Journal Line Tmp2 |
Ledger Load |
Led Load Temp Record Led Load Temp Record 2 |
Multicurrency |
MultiCurrency Tmp MultiCurrency Tmp1 |
TREE_SELnn_R |
Close Budget |
N/A |
N/A |
CFV_SEL KK_RSCFV_SEL TREE_SELnn_R |
