Using the PeopleSoft Classic General Ledger WorkCenter - Reports and Processes Pagelet
Use the Reports/Processes pagelet of the Reports/Queries pagelet group to easily access links to commonly-used report and process run controls. The system administrator can add links to this pagelet and determine whether an end user can configure their pagelet. The objective of this pagelet is to minimize the number of clicks to access commonly-used reports or processes and their results.
Navigation:
General Ledger, and then GL WorkCenter, and then Reports/Queries, and then Reports/Processes
This example illustrates the fields and controls on the PeopleSoft Classic General Ledger WorkCenter - Reports/Processes Pagelet.
PeopleSoft delivers the PeopleSoft Classic General Ledger WorkCenter, Reports/Processes pagelet with sample links as pictured in the example and categorized within the following groups:
  • My Processes – Provides quick access to run control pages of your most commonly-used processes.
  • Monitor – Provides quick access to Process Monitor, Reporting Console, and Report Manager.
  • Journal Reports
  • Other Reports – Provides convenient access to your most commonly run reports, such as Trial Balance or Open Item Listing.
You can personalize your Reports/Processes pagelet to suit your organizational needs. For more information, see Enterprise Components: Setting Up Pagelets for Reports and Processes as a System Administrator.
