Using Work Management in the General Ledger WorkCenter
The PeopleSoft Fluid General Ledger WorkCenter can optionally use the Work Management Framework, which is an Enterprise Components feature.
This topic discusses how to setup up Work Management for the General Ledger WorkCenter and provides examples for addressing Journals with Errors.
Understanding Work Management in the General Ledger WorkCenter
The purpose of the Work Management Framework is to view and manage transactions when they appear in the My Work section of the WorkCenter.
It is important to understand the Work Management Framework from a high-level perspective before applying it to PeopleSoft General ledger. Please review Enterprise Components: Understanding the Work Management Framework prior to reading the following information.
The Work Management framework is designed track and address errors and warnings when a system-based resolution is not available. It assists the person who has the best knowledge of your organization's finance and accounting policies. You can take various actions to resolve the transaction issue, track comments, assign a transaction to yourself for future follow-up, or inactivate a transaction if it is not a valid issue.
Some examples of General Ledger transactions where Work Management can be useful are:
A journal is in error dues to an invalid ChartField combination.
This example appears in the Journals with Errors section.
A journal is not posted for some reason and your period end is approaching.
This example appears in the Journals Approaching Period End section.
An Amortization Schedule has not been approved.
This example appears in the Amortization Schedule section.
One or more people can work on Work Management transactions in your organization. If another user acts on a transaction, you can view the transactions assigned to that person by changing your view to All Assigned. This view displays all transactions regardless of who it is assigned to. Select the Exception History action and view the name in the User Name column to discover who is working on a transaction.
Setting Up Work Management for the General Ledger WorkCenter
This list provides the steps to setup the optional Work Management feature for the General Ledger WorkCenter:
Use the EOXC_USER role to access the Work Management setup pages.
Access the Enterprise Components: Work Management Link ID's Page.
Search for the corresponding Link ID (component ID) for each type of transaction where you want to use the Work Management feature.
General Ledger transactions and their corresponding Link ID are:
Link ID Description GLAMRCLOSE
Amortization Vouchers Closed
GLAMRPYMT
Amortization Voucher Payment Canceled
GLAMRTSCH
GL_JRNLSINCOMPLETE
Incomplete Journals
GL_JRNL_APPR_PEREND
GL_JRNL_BALERRORS
Journals with Balance Errors
GL_JRNL_CNTLTOTERRORS
Journals with Control Total Errors
GL_JRNL_EDITERRORS
Journals with Edit Errors
GL_JRNL_ERRORS
GL_JRNL_OPEN_AFTOPNPER
Journals Not Yet Posted at Period End
GL_JRNL_PAST_CLOSEDPER
Journals Not Posted in Closed Period
PUSHBACKORDENIEDJRNLS
Pushed Back / Denied Journals
GL_JRNL_SUSPENSE
Journals in Suspense
JOURNALSWITHKKEXCEPTIO
Journals - Commitment Control Exceptions
BUDGETJRNLXCP
Budget Journal Exceptions
JRNLSPENDINGAPPROVAL
Journals Pending My Approval
Select the View button to access the Enterprise Components: Enable Work Mgmt Exception Page.
Select the Enable option to activate the Work Management feature for that transaction.
Follow instructions in the Enterprise Components documentation for the Enterprise Components: Enable Work Mgmt Exception Page to complete your setup.
Use the EPGL3000 permission list to access the General Ledger WorkCenter.
This has not changed with the Work Management feature.
Page Used to Manage Work in the General Ledger WorkCenter
| Page Name | Definition Name | Usage |
NA |
Access and manage outstanding transactions in various views. |
General Ledger WorkCenter Page (Work Management Enabled)
Use the General Ledger WorkCenter page when Work Management is enabled to access and manage outstanding transactions in various views.
Navigation:
Select the General Ledger WorkCenter tile, expand My Work, and select a transaction from the Exceptions section.
This example illustrates the fields and controls on the General Ledger WorkCenter - Journals with Errors page when Work Management is enabled.
When Work Management is enabled for an exception, there are two changes on the WorkCenter page:
The View drop-down box appears above the grid.
Additional action options are added to the Actions button.
The original action options remain. The additional (Work Management) action options depend on the View option selected.
The initial actions for Outstanding Cash Advances are Reconcile Cash Advance, Notify Employee, and Notify Manager. When Work Management is enabled, additional actions are available depending on the option selected in the View field: See Enterprise Components: Understanding the Work Management Framework, Actions by View section.
Work Management Example for Journals with Errors
The following example explains how you might approach a long list of journals with errors.
Upon enabling Work Management for Journals with Errors, you have a list of nine transactions.
Your first step might be to inactivate all Journals that are NOT true errors. For example, you notice that a journal is for a future period that hasn’t been opened yet.
To do this:
Select the Actions icon from the Unassigned view.
Select Mark as Inactive.
In the Exception Comments window, enter text to indicate why you are inactivating the exception, such as, "Accounting period is not open yet."
Select Done.
When you change the View to Inactive, you see this exception.
Now you're left with eight exceptions in the Unassigned view. There are two transactions where you want to notify the employee's manager.
To do this:
Select the Update Selected Rows icon.
Select the check box for the two rows you want to assign to yourself.
Select the Actions button.
Select Assign to Me.
In the Exception Comments window, verify the follow-up date, which defaults from the Work Management page.
Enter a comment that describes your action, such as, "Follow up with Jane Doe next week about invalid ChartField errors."
Select Done.
Click OK to the verification message.
These transactions move to the Assigned to Me view until the follow up date is reached. When the follow up date is reached, the system moves the transaction into the Unassigned view.
You now have six exceptions that appear in the Unassigned view.
