PeopleSoft Contracts and PeopleSoft Project Costing
Through the award generation process, PeopleSoft Grants writes award information to PeopleSoft Contracts and PeopleSoft Project Costing. For awards that do not have a proposal (blue bird awards), you must enter information directly into PeopleSoft Contracts and PeopleSoft Project Costing.
The system writes data to these PeopleSoft Contracts tables during the PeopleSoft Grants award generation process:
  • CA_CONTR_HDR
  • CA_BILL_PLAN
  • CA_ACCTPLAN
  • CA_DETAIL
  • CA_DTL_DST_DATE
  • CA_DETAIL_UAR
  • CA_RATE
  • CA_DETAIL_PROJ
The system writes data to these PeopleSoft Project Costing tables during the PeopleSoft Grants award generation process:
  • PROJECT
  • PROJ_ACTIVITY
  • PROJ_DOCUMENT
  • PROJ_LOCATION
  • PROJECT_MGR
  • PROJECT_TEAM
  • PC_BUD_PLAN
  • PC_BUD_DETAIL
PeopleSoft Project Costing integrates with both PeopleSoft Billing and PeopleSoft Contracts, so any adjustments, discounts, released retainages, or limits that are created for project-related bills are inherited from corresponding bills and contracts.
PeopleSoft Grants uses the fundamental structure of PeopleSoft Project Costing to write general project information, project activity information, and budget information directly to PeopleSoft Project Costing.
Any scanning, imaging, or attachments of electronic award notifications are institution specific. You can modify additional validation checks and required fields based on internal project approval requirements. You can also decide to build interfaces that populate or update project records and sponsor websites, electronic data interchange (EDI) transaction sets, and data warehouses.
