Project Analysis
PeopleSoft Project Costing provides several different ways to analyze project data. Before you can begin analyzing project data, you must create:
At least one project.
Project activities.
Transactions that have been assigned resource IDs.
After you establish a project and enter data directly though interfaces with other PeopleSoft applications, you can use the pages in PeopleSoft Project Costing to:
View a list of all project manager projects.
Display real-time project information that is imported from the project summary tables.
Display all resource transactions for a selected project.
The system automatically populates the lines and analysis types that appear in the Project Analysis pages. When you post lines in the Project Budget pages to PeopleSoft Project Costing, the system adds BUD (budget) lines to the Project Analysis pages. After you run the Integrate Enterprise Data processes, you can use the Project Analysis pages to make inquiries on the data that originated from PeopleSoft General Ledger, PeopleSoft Inventory, PeopleSoft Payables, PeopleSoft Purchasing, and PeopleSoft Time and Labor.
Instructions on analyzing project data appear in the PeopleSoft Project Costing documentation.
Related Topics
