Transaction Flow Control
Three basic ways are available to control the flow of data coming into PeopleSoft Project Costing:
Set a project or activity to Inactive status.
In this case, the project and activity do not appear in the prompt lists of the PeopleSoft feeder systems.
Use status control options.
On the Status Types page, select the analysis types that each feeder system uses; and then select a project control action to associate with the analysis type.
No project control action occurs if the Project Control Action check box is deselected.
Values include:
Warning: Displays a warning before the system accepts the transaction.
Reject: Rejects the transaction.
Use the PeopleSoft Commitment Control tolerance percentage.
After you create a budget, you can establish a setting to trigger a commitment control exception that allows up to a specified percentage over the budget.
Instructions on controlling incoming transactions appear in the PeopleSoft Project Costing documentation.
