Common Elements Used to Understand Par Location Management
Field or Control Description
Distrib. Type (distribution type)
Material stock requests generated for stock-replenished items use the distribution type that you define in the Define Par Location component.
ChartField Overrides
Click to access the ChartField Overrides page, where you can update ChartField and project information at the par location header level. You can override ChartField information for specific par location lines on the Define Par Location - Line page.
Default Quantity Option
Select the type of quantity that you want to enter for par location counts. Define a default value on the Define Par Location - Header page; you can override this value for individual counts on the Count Par Location Levels page. Values are:
Count Qty(count quantity): The quantity that is entered during the count is the quantity on hand. The Create Par Replenishment Requests process uses this value to calculate order quantity.
Request Qty (request quantity): The quantity that is entered during the count is the quantity that the Create Par Replenishment Requests process should order.
(Par Location) Sort Option
Determines how the system sorts data (by item, compartment, or count order). You can use this sorting option for the lines that appear on the Define Par Location - Line Details page or for the Par Location Count Listing report.
