Product Mapping for Hardware Assets Page
Use the Product Mapping for Hardware Assets page (RF_PROD_MAP) to map asset information to Product ID in CRM database.
Navigation:
Set Up CRM, and then Common Definitions, and then Integration Rules, and then Integration Defaults, and then Asset Product Mapping
This example illustrates the fields and controls on the Product Mapping for Hardware Assets page.
The Asset Subtype and Manufacturer ID should have been synchronized between CRM as part of the integration with HRMS.
