PeopleSoft Maintenance Management Implementation
PeopleSoft Setup Manager enables you to generate a list of setup tasks for your organization based on the features that you are implementing. The setup tasks include the components that you must set up, listed in the order in which you must enter data into the component tables, and links to the corresponding documentation.
Other Sources of Information
In the planning phase of your implementation, take advantage of all PeopleSoft sources of information, including the installation guides, table-loading sequences, and data models. A complete list of these resources appears in the preface in the documentation PeopleSoft Application Fundamentals with information about where to find the most current version of each.
See the product documentation for PeopleTools: Setup Manager
