Using the Crew Schedule Inquiry
This section discusses how to review the Crew Schedule Inquiry.
Pages Used to Use the Crew Schedule Inquiry
| Page Name | Definition Name | Navigation | Usage |
WM_CS_INQ |
Review the past, current, and future schedules for a selected crew. |
Work Order |
WM_WO_HDR |
Access and update the work order depending on user authorizations. |
WO Task Description |
WM_TSK_DESC2_SEC |
Click the Task Description link on the Crew Schedule Work Inquiry page - Crew Assignment tab. |
Review the work order ID, business unit, task number, and description associated with a selected task. |
Schedules |
WM_WO_TASK_SCHED |
Click the Yes or No link associated with Labor, Tools, Inventory, or Purchase/On-Hand on the Crew Schedule Work Inquiry page - Resources tab. |
Access the Labor Schedules grids, Tool Schedules grids, Inventory Schedules grids, or Purchase/On-Hand Schedules grids on the Schedules page in the Work Order and update if authorized to do so. |
Asset Information |
WM_WO_ASSET_SEC |
Click the Asset ID - Descriptions link on the Crew Schedule Work Inquiry page - Asset Information tab. |
Review information about the asset selected for a task. |
Crew Schedule Work Inquiry Page
Use the Crew Schedule Work Inquiry page (WM_CS_INQ) to review the past, current, and future schedules for a selected crew.
Navigation:
You must select a work order business unit, shop, crew and period range start date to search for a crew schedule inquiry. Selecting a craft is optional. If you do not select an end date to the period range, the system displays all schedules with dates equal to or greater than the period range start date.
When you click the Search button, a list of work orders and their associated tasks, which are scheduled and approved for the selected crew displays based on the start date (and end date, if selected) that you entered. This inquiry enables you to view the work order task, its scheduled start/end date time, completed date, associated resources, and asset information if authorized.
