Using the Work Progress Tracking Inquiry
These topics discuss how to track work progress.
Pages Used to Track Work Progress
Work Progress Tracking Page
WM_WOE_TWP
Review work order progress.
(Resource Name) Workbench
WM_WOTSK_WORKBENCH
Search for and review work order tasks assigned to a specific technician.
Work Order Details
WM_WOE_DETAIL
Displays the work order header and task details.
Schedules
WM_WO_TASK_SCHED
Review the details of the selected task in the work order.
Use the Work Progress Tracking page (WM_WOE_TWP) to review work order progress.
Navigation:
Maintenance Management, and then Inquiries and Reports, and then Work Progress Tracking
Field or Control Description
Task Search View
Select a view that you previously created to narrow your search for work order tasks that are behind schedule.
View
Click this button to access the Task Search page where you specify the criteria used to search for certain work order tasks. On this page, you can also select the basis date to determine whether tasks are considered behind schedule for the inquiry based on the scheduled start date (the task started late), scheduled end date (the task ended late), both or either of those dates. When you save this search page and name the view, it becomes available for selection in the Task Search View drop-down list. This eliminates the need to specify the search criteria multiple times.
See Work Order Workbench - Task Search Page.
Results
When you click the Search button, a summary of the results of the search appear in the Results group box.
Total
Displays the total number of work order tasks that were considered based on the search.
Workbench
Click this link to access the Work Order Workbench and view a list of all the tasks returned by the search.
Total Behind Schedule
Displays the total number of the work order tasks in the list and that are thus behind schedule. Only those tasks that are behind schedule are listed.
Percent behind
Displays the percentage of the considered tasks that are behind schedule for the given search.
Tasks Behind Schedule
Lists the tasks that are behind schedule based on your search.
  • Select the Details tab to view work order ID, work order task number, the scheduled end date, the actual end date for the task, and the number of end days each task is behind.
    If the task has not ended, the actual end date is blank, and the end days behind is the difference between the scheduled end date and the current date. This same logic applies if you chose the scheduled start date as your basis date. In that case, the actual start date or current date is used in the days behind calculation.
    Click the Work Order ID link to display the Work Order Details page, which consists of the work order header details associated with the selected task, any work order header notes, and a list of all of the tasks that are associated with the work order. A description of each task, the task's status, and any asset information appears in the Task Details grid. The scheduled start and end dates and times of each task appears in Task Dates grid.
    You can also click the Task number link on in the Details grid to access the actual task in the Schedules page of the work order.
  • Select the Details 2 tab to view additional details about each task, including the shop ID, scheduler's name, specific asset information, and project information associated with the work order task.
