Using Manufacturing Execution System Transactions
When you add or modify production with a status of Firmed or greater, component lists, operation lists, and output lists, the system creates a publish message for the MES to pick up. The system also creates a publish message when changes are made using background programs.
You manage errors for the Completions and Edit/Issues transactions using Transaction Maintenance.
You use the Publish Outbound Transactions page to initiate the outbound publish process for the Production Order Update EIP and the Item Master outbound EIP.
Using the Item Master Transaction
You can publish item revision information to the Manufacturing Execution System using the Item Master outbound EIP. This is an outbound, asynchronous message. When you create or modify a revision, approve a revision-controlled item, or add business unit attributes to a revision-controlled item, the system publishes an item revision message to the Manufacturing Execution System.
Using the Production ID/Production Schedule Manufacturing Execution System Transaction
Use the Production Order Update EIP to export production ID or production schedule changes to an external system. This is an outbound, asynchronous message.
Using the Completions Manufacturing Execution System Transaction
Use the Production Completions EIP to import information into PeopleSoft Manufacturing. This is an inbound, asynchronous message.
See Understanding the Process of Recording Completions and Scrap Using Electronic Data Collection.
Using the Edit/Issues Manufacturing Execution System Transaction
Use the Production Order Issue EIP to import edit or issue component information from a third-party system. This is an inbound, asynchronous message.
