Using Production Calendar Codes
With PeopleSoft Manufacturing, you can create standard and alternate production calendars for your enterprise to cover an entire year or a partial year. You create one or more calendar codes and enter calendar information for each code. You can assign alternate calendar codes to work centers whose hours of operation differ from that of the business unit. In addition, if you are using PeopleSoft Supply Planning, you can assign these calendar codes to resources.
You can assign a single calendar code and its associated calendar to multiple work centers if they have similar working and nonworking days.
This section discusses:
  • The process to define production calendar codes.
  • The scheduling hierarchy to determine available production time.
  • How to assign calendar codes to business units, work centers, and resources.
