Using Production Options with Other PeopleSoft Applications
You define production options in PeopleSoft Manufacturing, but they also are present in PeopleSoft Supply Planning and PeopleSoft Cost Management. While the specifics of these impacts are discussed in the respective pieces of application documentation, this is a high-level discussion of the cross-product use of production options.
Use production options with PeopleSoft Supply Planning.
Use production options with PeopleSoft Manufacturing.
