Common Elements Used to Understand Mobile Par Location Counts
| Field or Control | Description |
Alternate Item Display |
Select an option that indicates how an item, alternate item, or both are displayed when an alternate item is specified for the transaction. Options include: Alternate Only, Alternate as Primary, Item Only, and Item as Primary. |
All Item Filter |
Select a value to define how you want the mobile device to display items. Values include:
Count Status to Include |
Use this section to define which count statuses will be included in the mobile count pages. The system provides these values as default values on mobile devices. You can override the default values using a mobile device. Count statuses include:
Count UOM Enabled (count unit of measure enabled) |
Select to set mobile device pages to enable an item's count unit of measure. You can change the value using the Options link on Inventory Count pages |
Delivery Signature Required |
Select to indicate that the mobile application requires a signature of the person receiving a delivery. When this option is selected, the Perform Delivery page requires a signature prior to saving the page. |
Display Description |
Select to display the item descriptions on the count pages on the mobile device. |
Display Filter Related Fields |
Select to display the Filter field and Filter button on the Mobile Inventory Management count pages. Deselect the check box to remove the filter functionality from the pages. |
Display Prior Entry Caption |
Select to display the last item counted for the current mobile count page. When selected, the system displays the Last Item Counted table. When you count an item, the table is updated with that item. The table displays one item at a time. As you add to the count, only the most recent item appears |
Display Lookups |
Select to display the Lookup icon for the business unit and item fields at the top of Mobile Inventory count page on the mobile device. The Lookup icon enables you to view a list of options and select one. |
Display Show/Hide in tables |
Select to display the Show/Hide icon in count item lists for Mobile Count pages. You can use this icon to manually expand and collapse item description sections. Note: When not selected the system only displays basic information for each row in the table. |
Filter All Alternate Items |
Select to indicate that you want the system to search through all possible alternate items when filtering a table. If an alternate item identifier is entered in the Filter field, the item ID (MASTER_ITEM_TBL) that matches the alternate is shown in the table. Deselect to indicate that only the item ID is to be used for filtering, which also improves system performance. |
Group |
A distinct set of event detail line items. You can divide a counting event into groups in the PeopleSoft system so that multiple users can simultaneously update the same counting event using the Mobile Inventory Management count applications. You can divide the event based on item IDs or storage locations using a certain number of groups or a certain number of items or locations for each group. |
Group by |
Select how you want to group items on the mobile device. This will group like items and locations on the display all page. The groups are displayed in the page navigation. The Group by field is not enabled for counts by location and counts by item. Values include:
Initial Display Mode |
Select to define the initial display setting for mobile count pages. The system provides these values as default values on mobile devices. You can override the default values using a mobile device. This value is only applicable to guided counts. Initial display values include:
Pre-Load Serial IDs |
Select to preload serial IDs for Mobile Count pages. This setting is for event detail line items that are serial-controlled items. This check box is not available for manual counts. |
Rows Displayed |
Enter the maximum number of items to display in the tables for the Mobile Inventory Management count pages. When there are more rows of data than the value you enter, you can scroll through additional rows by using the Next link on the Mobile Inventory Management count pages. You can also change the number of rows displayed using mobile devices. |
Sort By |
Select to define the initial display setting for mobile count pages when you are displaying all items. The system provides these values as default values on mobile devices. You can override the default values using a mobile device. Sort option values include:
Task Flow |
Identifies the Mobile Inventory Management task flow that uses the settings on this page. When you select a task flow, you can then use the lower portion of the Mobile Inventory Installation Options page to define default values and search and display options. Mobile devices use the information defined for the task flow as default values. Select a value to define installation-level options for these tasks:
If task flows already exist for user preferences and installation options, use the Show previous Row and Show Next Row buttons to locate the type of count you want to maintain. If you are adding task flow setting, select the task flow from the Task Flow field list of values. |
