Additional Fields Available for Mobile Par Location Counts
The following fields from the PeopleSoft Inventory system can be displayed on the par count pages on the mobile device if you customize your display.
  • The par location group defined on the par location (Define Par Location - Header page).
  • The item's count order and optimal quantity within the par location (Define Par Location - Line page).
  • The compartment ID where the item is located within the par location (Define Par Location - Line page).
  • The item's average usage within the par location (Define Par Location - Line Details page).
  • The count status of the par location count ID (the header level of the Count Par Location Levels page).
  • The Sufficient Stock, Last User ID, and Last Changed fields of the par location count ID (the line level of the Count Par Location Levels page).
