Performing Fulfillment Inquiries Using the PeopleSoft Fluid User Interface
This topic discusses how to perform Fulfillment Inquiries.
Pages Used to Performing Fulfillment Inquiries Using the PeopleSoft Fluid User Interface on a Mobile Device
Page Name Usage
Fulfillment Inquiry - Fluid Search Page
Search for items to Fulfill.
Fulfillment Inquiry - Fluid Fulfillment Status Summary Page
View the fulfillment status of available demand lines.
Fulfillment Inquiry - Fluid Specific Order Lines Page
View available order lines.
Fulfillment Inquiry - Fluid Order Line Details Page
View order line details.
Use the Fulfillment Inquiry - Fluid Search Page to search for items to fulfill.
Navigation:
Mobile Inventory, and then Fulfillment Inquiry
This example illustrates the fields and controls on the Fulfillment Inquiry - Fluid Search page. You can find definitions for the fields and controls later on this page.
Enter item search information for a particular fulfillment inquiry from the following:
Field or Control Description
Business Unit
Displays the user's default business unit. You can change the business unit. The field is required.
Source
Select a source from the drop-down list.
Source Unit
Enter a source business unit.
Order No
Enter the order number.
State
Select an available fulfillment state.
Item ID
Select a PeopleSoft system item ID on which to base the search. You can use the lookup icon to locate and select an item ID.
Location
Enter location information.
Dest Unit
Enter destination unit information.
Ship To
Enter the associated ship-to customer information.
Sched Date
Select a scheduled date option. The available values are Range, Specific and Today.
An additional option allows you to enter relative date values.
Ship Date
Select a ship date option. The available values are Range, Specific and Today.
Additional Options
Expand to use additional filters needed to find orders. The available options include Display total allocated quantity, Defer Deplete lines only, Hold and Backorders.
Use the Fulfillment Inquiry - Fluid Fulfillment Status Summary page to view the fulfillment status of available demand lines.
Navigation:
Mobile Inventory, and then Fulfillment Inquiry, and then and click an order number link.
This example illustrates the fields and controls on the Fulfillment Inquiry - Fluid Grid Mode page. You can find definitions for the fields and controls later on this page.
Fulfillment Inquiry - Fluid Grid View Page
You can filter stock requests using keywords in the filter field on top of the page and selecting appropriate Line Totals check boxes.
This example illustrates the fields and controls on the Fulfillment Inquiry - Fluid List Mode page. You can find definitions for the fields and controls later on this page.
Fulfillment Inquiry - Fluid List View Page
Return
Click to navigate to the previous page.
Exit
Click to navigate to the Fulfillment Inquiry — Fluid Search page.
Comments & Attachments
Click to view the comments and list of available attachments. On the Comments & Attachments page, click any attachment file name link to view or download it.
Use the Fulfillment Inquiry - Fluid Specific Order Lines page to view available order lines.
Navigation:
Mobile Inventory, and then Fulfillment Inquiry, and then and click an order line link.
This example illustrates the fields and controls on the Fulfillment Inquiry - Fluid Specific Order lines page. You can find definitions for the fields and controls later on this page.
Fulfillment Inquiry - Fluid Specific Order lines Page
Use the Fulfillment Inquiry - Fluid Order Lines Details page to view order line details .
Navigation:
Mobile Inventory, and then Fulfillment Inquiry, and then and view details.
This example illustrates the fields and controls on the Fulfillment Inquiry - Fluid Order Line Details page. You can find definitions for the fields and controls later on this page.
