Adding Mass Change Definitions in PeopleSoft Order Management
Use the Mass Change pages to add or modify the processes that use mass change in PeopleSoft Order Management.
The topic discusses how to add mass change definitions in PeopleSoft Order Management.
Pages Used to Add Mass Change Definitions
Mass Change Definition - Description
MC_DEFN_00
Enter a description for the mass change definition.
Mass Change Definition - Criteria and Defaults Page
MC_DEFN_01
Create a default value to appear in a field without user intervention.
Mass Change Definition - OM Specific Fields Page
MC_DEFN_OM
View additional parameters for the Mass Change Definition.
Mass Change Definition - Generate SQL Page
MC_DEFN_02
Synchronize the mass change SQL with any new table changes that are in the PeopleSoft Order Management system. This may be needed when modifications are made or if fields are added for bug fixes or product upgrades.
Mass Change Definition - Execution History
MC_DEFN_03
Displays history for the Mass Change Definition.
Use the Mass Change Definition - Criteria and Defaults page (MC_DEFN_01) to create a default value to appear in a field without user intervention.
Navigation:
Set Up Financials/Supply Chain, and then Product Related, and then Order Management Foundation, and then Mass Change Definition, and then Criteria and Defaults
Field or Control Description
Field
Select values from the available options. Select any filtering or qualifying symbol (that is, between, =, >, or <); depending on the selection, enter the value (that is, between 1 and 100, or > 100).
Use the Mass Change Definition - Generate SQL page (MC_DEFN_02) to synchronize the mass change SQL with any new table changes that are in the PeopleSoft Order Management system.
Navigation:
Set Up Financials /Supply Chain, and then Product Related, and then Order Management Foundation, and then Mass Change Definition, and then Generate SQL
Count
The button runs against the database and determines the total number of rows that are to be processed with the SQL component.
